New MR 29.4 Beta - L3 DHCP and Umbrella DNS fixes, 50+ iPSK
Wireless firmware versions MR 29.4 changelog
Important note
Meraki APs use UDP port 7351 for cloud communication and TCP ports 80 and 443 for backup communications when running MR 27 and older firmware. When running MR 28+ firmware, Meraki APs will now use TCP port 443 as the primary means for cloud connectivity. In order to maintain connectivity to the Meraki cloud on MR 28+ ensure that TCP port 443 is allowed to communicate with 209.206.48.0/20 on firewalls that are deployed upstream of your Meraki APs. (Wi-Fi 6 and Wi-Fi 6E APs)
Legacy product notice
When configured for this version, MR12, MR16, MR18, MR24, MR26, MR32, MR34, MR62, MR66, and MR72 will run MR 26.8.3.
Bug fixes
General stability and performance improvements
‘No DHCP response’ error using L3 Roaming
‘DNS misconfigured’ error while using Umbrella DNS
iPSK w/o RADIUS now supports 50+ PSKs
Known issues
Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 5 Wave 2 and Wi-Fi 6 APs)
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7b8821fd1a3a79","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7b8821fd1a3a79_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7b8821fd1a3a79_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7b8821fd1a3a79_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_7b8821f48ad9aa","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
