Multiple VLANs to a single SSID
HunterMatthews
Hey Meraki Community,
I am wanting to know if this is possible. We are currently running a network with 15 SSID's and we want to condense this to a single SSID. The problem we are running into is how do we set-up multiple VLAN's on a single SSID? I am not seeing this option through the GUI?
5 Replies 5
kYutobi
If you create a "Network Wide" / "group policy" you can tag a VLAN there. After that is created you can assign the policy by MAC address of the client like so:
Enthusiast
jdsilva
To add to @kYutobi 's reply, if you're using a RADIUS server you can return a VLAN value in the Accept message that specifies a VLAN. You need to enable it under Wireless > Access control here:
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/RADIUS_Override
kYutobi
Thanks for the addition @jdsilva  🙌
Enthusiast
BrechtSchamp
To further add to the terrific responses, you can also assign a different vlan for the same ssid based on the tag assigned to the AP. This is often done if you would have too many users in a single vlan (broadcast domain). More info here:
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/VLAN_Tagging_on_MR_Access_Points
Look for the section called Per-AP multiple VLAN tagging
jdsilva
Haha! Anyone else got a way to do this they'd like to mention?
