To confirm which SSIDs are actually broadcasting on 6 GHz:
Go to Wireless > Monitor > Access Points
Click on an AP (CW9164)
Click the “RF” tab
Scroll to the 6 GHz band section
Look under “SSID(s)”, it will list exactly which SSIDs are broadcasting on that band
If Corporate isn’t listed there, it’s not being broadcast on 6 GHz, even if configured correctly elsewhere.
Temporarily disable the Guest SSID
Reboot an AP
Re-survey with Sidekick2
See if Corporate now appears on 6 GHz
