Modify "sponsor.html" for Splash Page
Systems
we want to modify the "sponsor.html" for the Splash Page. In this case, we would like to make the value of the input "sponsor_mail" equals to a fixed email and also to do this input "readonly" to avoid the users not modifying this value by the user.
I think that this could be done knowing the equivalent code to this variable "$MERAKI:MODERN_AUTH_SPONSOR_INFORMATION_FORM$" but we do not find this in any documentation.
Would this be possible?
Thank you in advance
Regards
You can edit the HTML, but to be honest, you need to apply the code and test it to see if it will work.
https://documentation.meraki.com/MR/MR_Splash_Page/Custom_Splash_Page_Themes
Systems
Hello, thank you for your response.
I know that I can modify the HTML of the page, but I have made some changes and I am not able to get what I want to.
Firstable, I do not know what exactly it is the code that introduces this variable $MERAKI:MODERN_AUTH_SPONSOR_INFORMATION_FORM$. In the inspector of the browser I can see that some script JS lines are added but when I try to do it by myself I cannot add any JS lines in the file.
Is there any full documentation about these variables?
Regards
Nope, you have to try it by yourself.
MeraWi
Hi @Systems were you able to fix this?
I'm in the same situation, need to allow only a single email (hidden or fixed).
Deleting the variable "MERAKI:MODERN_AUTH_SPONSOR_INFORMATION_FORM" and raw putting code inside did work?
Or did you find another way?
