Meraki in Palau
T-Ryu
Meraki in Palau
Dear PIC,
We are IT vendor and managing customer's network globally.
I would like to know if we could purchase and use Meraki WIFI, Switch, FW in Palau or not.
If can be used, please kindly advise the distributors in Palau.
Best Regards,
Ryu
Cisco Meraki products, including Wi-Fi access points, switches, and firewalls, are designed to be deployed, secured, and monitored at scale. They are used globally and are likely to be available for use in Palau. But, I recommend you reaching out to Cisco Meraki directly or a local IT distributor for the most accurate information.
Thank you for sharing.  I will ask Cisco sales.
Brash
Cisco has both a partner locator and distributor locator tool. However they both show no results for Palau.
https://locatr.cloudapps.cisco.com/WWChannels/LOCATR/openBasicSearch.do
https://www.ciscochannelconnect.com/DistiLocator
I suggest contacting Cisco Sales with the following form to confirm what your options are.
https://engage2demand.cisco.com/LP=5642
