Meraki guest wifi account with Securew2 integration
JD100
Does anyone have documentation to configure Meraki open guest wireless ssid that uses Captive portal on SecureW2 for guest registration? I'd also like to see the Securew2 side that requires self registration.
thanks
5 Replies 5
Check it out.
https://www.securew2.com/solutions/wi-fi-integrations/how-to-setup-eap-tls-with-meraki-access-points
JD100
Thank you for the reply. Does that mean the only choice is to use certificates if you integrate with SecureW2 (even for guest wireless)?  Maybe the better option is use the Meraki captive portal?
What the SecureW2 documentation implies is that it only supports certificates.
However, if they only work with radius servers, you can use them with a splash page.
See section V of the link I sent you.
You can also check this document https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Configuring_RADIUS_Au...
JD100
I decided to stick with the Meraki guest self registration for 2 different types of SSID:
Guest - user automatically authorized
BYOD devices - user needs to be approved by Adminstrator
Do a lot of people use this builtin Meraki method? Doesn't look like there a way to automatically deleted expired accounts.
thanks again
Yes, I have many clients who use this method, of course it all depends on the client's needs.
There is no way to automatically delete accounts after they expire.
