Meraki Wireless Authentication to Clearpass
JMC_
Greetings,
Just want to check if anyone has experience integrating Meraki wireless to Aruba Clearpass radius. This is a new setup, we use SSID with a radius setting and with splash page wherein this will be redirected to Clearpass to authenticate the users via AD.  After the user was successfully authenticated via Clearpass, for sometime after coming back the next day, the user needs to forget the SSID to be able to authenticate back, I am checking if there is needed to adjust on radius settings. Below is the screenshot. Appreciate the response. Thank you.
1 Reply 1
I believe this video can help you.
https://www.youtube.com/watch?v=L_RSx9rKNx0
