Meraki Sponsored Guest Splash Page
JasonNgAcuutech
It seems that there isn't a way in the Meraki Dashboard to view which email the Sponsored Guest client used to register for the Wi-Fi.
We can only view the Authoriser when viewing through the client page.
Is there any way through API?
2 Replies 2
unfortunately not.
Brash
No, this is not available in the dashboard via GUI or API.
If this is a requirement, you might need to investigate 3rd party options to integrate into the guest access workflow
