Meraki MR with Huawei Switch S5735
Naresh_Bhardwaj
Hi All,
We have Huawei devices in out environment however we want to use Cisco Meraki solution for Wireless (MR Cloud-Managed Wireless Access Points ).
Its possible to run Meraki MR on Huawei switchs.
2 Replies 2
Yes no problem.
Just check the PoE requirements of the ap if you use PoE from the switch
DarrenOC
Absolutely no reason why this shouldn’t work. As @ww states, best check the PoE requirements of the APs and what the switch can provide.
we have Meraki MRs working on Dell, HP, Cisco with no issues.
