Meraki MR + MX mesh
DavidD96
Meraki MR + MX mesh
I've searched online and struggling to find a yes or no answer to keep it simple.
Has anyone ever sucessfully been able to configure a MX device (broadcasting the same SSID's) to a MR33/MR44 in a mesh using repeater mode to seemlessly keep signal (no loss of service)
Any help and guidence would be a massive help. Thank you
2 Replies 2
Ryan_Miles
Meraki Employee All-Star
Meshing between MX and MR wireless is not supported. You can advertise the same SSID from a MX and MR, but it will not be mesh nor provide a coordinated roam/handoff.
a5it
While the Cisco Meraki MX series can provide wireless capabilities, its primary function is as a security appliance, not as a full-featured access point like the MR series. This means that while it can broadcast an SSID, it doesn't support more advanced wireless features, including mesh networking.
For seamless wireless coverage and signal handoff, you would need multiple MR devices. In this case, you would configure one MR33/MR44 as a gateway (connected to the MX device via Ethernet), and additional MR33/MR44 devices as repeaters. These repeaters would wirelessly connect to the gateway or other repeaters to form a mesh network.
By having all your MR devices broadcast the same SSID and configuring them correctly for mesh networking, client devices should be able to move between MR devices seamlessly without losing connection.
I hope this clarifies your question. If you have more questions or need further guidance, please don't hesitate to ask.
