Meraki CW9166I Access Point compatibility with WS-C3650-48FD
Maguy
Is Meraki CW9166I Access Point compatible with WS-C3650-48FD ?
2 Replies 2
K2_Josh
They both support POE+ and UPOE (depending on the switch model). And they both support Ethernet and trunk ports. So yes they're compatible.
Whether or not they integrate with the existing network configuration is a question that is best posed to a consultant who can better understand your needs.
Are you asking because of POE? This switch is POE+ so everything should be fine.
