Meraki CW9162 CW9163 unexpected reboot
EricZ
In the past days ,our APs unexpected reboot (except the AP14 in red frame) , the reason is as below .   I checked the log in switches ,only found port donw up event . These 4 APs are connected to 4 different Cisco 2960X switches.
AP01 is CW9162 and others are CW9163
I suggest you open a support case.
It sounds like the firmware crashed.  I would update them to the current stable release.
Brash
As said above:
  • Ensure the AP's are on the latest stable firmware release
  • Ensure that you haven't blown the PoE power budget for the switches (unlikely but worth checking)
  • If all AP's encountered the reboot, check to see if a firmware upgrade was automatically scheduled and applied to the network
  • Open a support case
EricZ
Yes ,I have opend a CASE and  meraki confirmed this was caused by the firmware crash unfortunately they did not addressed the route cause for it therefor there is no solution now .
I am sad for the ability for the meraki team.
