MX450 Performance capability
rsage_voda
My customer currently has 2 HA pair of MX450 acting solely as wireless concentrators. Due to a DC move they have questioned can these be consolidated into a single HA pair.
They have approximately 600 AP's with each AP supporting on average 5 tunnelled SSIDs. So approximately 3000 tunnels teleworker/roaming tunnels, split across the two HA pair. I am not clear as to what the difference is between these tunnels and a site to site tunnel as teleworker/roaming tunnels are not mentioned in the MX450 datasheet.
The MX sizing guide talks of a maximum of 5000 site to site VPN tunnels with a recommendation of 1500.
I presume this is based on CPU and or memory of the device. Neither of which seem to be available on the dashboard or via the API.
Does anyone have an relevant experience.
Ryan_Miles
Meraki Employee All-Star
A SSID tunnel should be considered the same as an AutoVPN (site to site) tunnel and therefore the same sizing guidelines would apply.
Ryan_Miles
RaphaelL
There is no way someone is near the advertised number of tunnels or throughput.
MX450 is long dead over 1.6-1.7 Gbps or 400K PPS.
So 5000 Tunnels with 0-5Kbps maybe.
mlefebvre
"Does anyone have an relevant experience."
Yes, and I would heavily recommend against consolidation here.
At your scale, you would have a Meraki Account manager.  I would engage with them and ask for an engineering resource (they could probably get a pre-sales engineer to help).  Seek advice from them.
