MX vs. MR RADIUS WiFI question
thrtnastrx1
I have some sites with MX64W's configured with one SSID, authentication to "My RADIUS server", and I have other sites with MS series configured with one SSID, authentication to "My RADIUS server" (both using the same server IP/port).
Using a Windows 10 laptop, domain joined, certificate from internal Enterprise CA,
When connecting to the MX wireless, left click on the network icon on the taskbar, I see the SSID, select it and "connect', the "Enter your user name and password" appears along with a link to "Connect using a certificate".  I choose certificate, select the cert, and it connects.
When connecting to the MS wireless, left click on the network icon on the taskbar, I see the SSID, select it and "connect', the "Enter your user name and password" appears but there is no option to "Connect using a certificate", using the same Windows 10 laptop.
So everything is the same except for the Meraki hardware.  How can I provide the same experience (provide the option "Connect using a certificate" to the users?
Those options are controlled by what the RADIUS server presents as allowed options to the machine.  Those options are transported inside of a PEAP packet, which is encrypted - so the AP doesn't know what you are offered or negotiate.
This is assuming you are using PEAP with MSCHAPv2 and PEAP with EAP-TLS.
Take a closer look at your RADIUS server config, and check the policies that are being matched in both cases.  More than likely it is matching different policies.
2 Replies 2
thrtnastrx1
Yes you were exactly correct, they were matching different policies.
Thank you for the suggestion!
