MT 20 Sensor question
Akash_5321
Just browsing
Hi Team,
Kindly help us to understanding on Data logging, how do I increase default sampling rate in MT 20 sensor. what about after 5 days.
Please help us to understand this.
Greenberet
Thats the "offline" Storage. The MT will log the data in the internal storage in the case of network/internet/dashboard outage. After the outage it will upload the internal data to the dashboard.
changing the sampling rate: probably just over a support case. At least I don't know any way.
Akash_53211
Thanks for sharing relevant information with us, in addition- could you please tell me:
For how long can this data be stored on the dashboard?
how I do can provision this device without any gap.
MT data is stored in the Meraki cloud and available through the dashboard for 1 year and you can view up to any 30 days at a time.  As for the gap, if you mean in coverage then make sure that an MV camera or MR access point (Wifi5 wave2 or newer) is nearby and in the same dashboard network.  The sensor will tell you the signal strength for any MRs or MVs it can see and the last time it communicated with them.
MerakiDave
@Akash_5321 what @Greenberet said is correct about the offline storage, in the event your network is down and the MT sensors have no Dashboard connectivity, they can cache reading for 5 days.
MT sensors are always sensing and report into Dashboard every 20 minutes, or immediately upon violations or a state change with customizable alerting you can configure. This default of 20 minutes regardless of state changes is in order to help guarantee the long battery life.  I've had my own MT20 in my home lab well over a year and the battery is currently at 70%.
Changing the sampling rate is possible on the back-end but is experimental only, it's not supported and could cause suboptimal performance and faster battery drain, so even Meraki Support may not be permitted to adjust.  What I mean is the 20 minute default is obviously something that is "configured" but it's a back-end setting not meant to be adjusted.
I would agree the wording in the data sheet "at the default sampling rate" leads one to believe it's adjustable.  It's not officially adjustable at this time.  Was there some concern about increasing the frequency at which the MT20 checks into Dashboard?
