MS365 credentials
gcooney14
MS365 credentials
Hello All,
Question... Do you all know if MS365 credentials can be an auth option for Meraki wireless?
Thanks!
-Greg
If you mean authenticating directing against AzureAD - not it can not.  If you had an on premise AD environment using ADConnect to AzureAD to do directory synchronisation then you could deploy a local Network Policy Server (RADIUS) to authenticate against,
10 Replies 10
gcooney14
That answers it. Thank you!
If you think I helped it would be great if you could give me some Kudo's.
BHEEM
How stable is AD authentication in terms of security, we have been advised by security experts to change to AD authentication to make the WiFi network more stable. We have similar setup us you mentioned.
Uberseehandel
Perhaps the simplest/cheapest way of implementing this is to set up AD Connect on a VM running a Nano Win2016 server, and linking that to Azure AD.
https://docs.microsoft.com/en-us/windows-server/identity/ad-fs/deployment/azure-active-directory-con...
Uberseehandel
use the link below
can't see what was wrong with previous link.
BHEEM
Thank you,
Uberseehandel
Apparently MS has been busy - Azure MFA with RADIUS authentication
As a solution to a different problem, I am looking at using a device that has a Radius server that can be synched with Azure AD, in the new year I shall attempt to get it working with AD and see if it can be used for WiFI authentication, without digging into the API.
I also use Univention's UCS which is cost effective
Per user authentication (such as AD Authentication) allows the user of WPA2-Enterprise mode, which generates per-user keys.  It is far superior to everyone using the same pre-shared key.
Take the simple task of administration.  If one person leaves, you disable their AD account and they can no longer access WiFi.  If you are using a pre-shared key they can either continue to access the network, or you have to change the pre-shared key on the WiFi network and every single device that connects to it.
Johan
