We have 802.11r enabled for fast roaming, but we are still getting MS Teams Dropouts when roaming occurs.
As we have Client balancing enabled, this is causing a lot of roaming to balance load(active load balancing).
We are planning to turn off Client balancing off to prevent this occurring(passive load balancing).
Question is will the AP's require a reboot to apply the new radio profile settings
I am thinking no, but just want to check before making this change in the middle of the day.
Changing radio settings doesn't require a reboot of the AP.
I don't believe changing client balancing impacts connected users but I've never tested.
I'd suggest making the change out of business hours just in case.
What AP are you using ?
What firmware version are you running ?
What kind of SSID ? WPA2-Enterprise ?
What devices are you using ?
What Wireless NIC cards ?
Any relevant info in the roaming client page ( https://documentation.meraki.com/MR/Client_Roaming_Analytics#:~:text=With%20the%20introduction%20of%.... )
MR56
Current version: MR 29.5.1
Encryption | 802.1X with custom RADIUS |
Sign-on method | None |
Bandwidth limit | unlimited |
Client IP assignment | Local LAN |
Clients blocked from using LAN | no |
Wired clients are part of Wi-Fi network | no |
VLAN tag | 170 |
VPN | Disabled |
Splash page | |
Splash page enabled | no |
Splash theme | n/a |
Client devices Lenovo laptops and MS surface
Wouldn't be surprised that you are hitting a know issue with Microsoft/Intel with 802.11r.
Do you have any logs in Wireless Health that indicates an issue with the roaming ?
The only indication we have is that there is a roam event in the logs and teams meeting takes a hit at that time. I have turned off client balancing and it seems to have stabilised some what, although one still had a roaming issue with a surface today, so I have changed the roaming aggressiveness down to low/medium on that device.
