Hello to the community,
I have a question if we use AIR-ANT2513P4M-N that is 13 dBm how much should the transmit power should be in order to be in regulation ?
for example if the power is 1dbm the EIRP is 14dbm (25 mW) which is the best practice for design.
Based on the regulation the maximum power should be 100mW (20dBm) this means that the maximum power when this antenna is plugged in is 7dbm.
Meraki mention the following For 5 GHz, Auto Power reduction algorithm allows TX power to go down only up to 8 dBm.
This means that the EIRP will be 21 dBm and can not be within the limits .Any idea ?
Thank you
