MR84 power options
CML_Todd
MR84 power options
Does the MR84 have an AC power option?  The data sheet only says PoE.  We will be replacing some Cisco 1552's that are mounted on light poles in a mesh configuration.  The 1552's are using an AC power cord.
I need to know if PoE injectors will have to be purchased.
BrechtSchamp
You'll need a PoE injector or a PoE switch. No direct power connection.
BrechtSchamp
CML_Todd
That's what I was afraid of, thanks for the quick response!
BrechtSchamp
You're welcome. For future reference: None of the current outdoor APs (MR70, MR74, MR84) have a power connector. The current indoor ones do, except for the MR30H (MR20, MR33, MR42, MR45, MR52, MR53, MR55).
kYutobi
Enthusiast
