MR66 connectivity
dsekely_brs
MR66 connectivity
Has anyone had issues with clients not connecting to MR66's?  I have a couple that the AP is on the network, broadcasting a signal on both bands but no clients will connect.  If I reboot the AP the clients connect and the AP will work as expected.  This happens randomly and I have not been able to find anything that might cause it and it is causing productivity issues as scanners/mobile printers start to lag and things take longer to process.  Users have to walk to a different area for their devices to work normally.
firmware version MR 26.8.3
What type of authentication are you using? Are 802.11w and 802.11r enabled?
dsekely_brs
Neither of those are used
Ryan_Miles
Meraki Employee All-Star
You should contact Meraki Support and have them roll you back to 25.13 and monitor if the issue still persists
