MR57
ahmed-baryoul
MR57
hello community
i'm facing a problem through the configuration of SSID of the MR 57
i create an account meraki then i create a network and attach the device to it
mooving on , i configure an SSID for the MR57 but the ssid does not appear in the wifi list but an SSID named "Meraki setup" appears
what is the problem ?
5 Replies 5
KarstenI
If you see this SSID, likely, the AP could not register with the cloud.
I would first reset the AP if it was used before somewhere else and make sure that it is connected to a port where a valid IP config is provided by DHCP.
Then make sure the AP comes online in the dashboard. After that you should see your configured SSID.
ahmed-baryoul
thanks
should i delete it from the Meraki dashboard ?
then after reset it i add it ?
KarstenI
You can leave it ion the dashboard network for the reset. It should come online shortly after.
A very relevant question here is, does the ap appear as online on the dashboard?
ahmed-baryoul
thanks
the problem is resolved
