Hi all,
At my company we have bought 40 MR36 AP's and are currently configuring them.
All but 1 turn on, we add a profile, and after a minute our Zebra scanners connect to them instantly.
The problem with the specific AP is that it turns on, the LED colors change a bit and stays green after a minute or so and we cannot connect our devices to the AP. The profile assigned to the AP is the same as the other ones which do work. The AP should send out an SSID but doesn't.
What we have done:
- Assigned a different RF profile, basic indoor profile
- Reset the device (multiple times)
- Ping is send and received to and from the AP
- Latest firmware installed
- Created a new profile with SSID visible but it still doesnt show up
Anyone has an idea on what to do?
