I've seen cases in which downgrading to older 25.x releases helps with stability on the older AP's. It's often case by case based on config and usage.
The last case I see on this opened by you was Dec 2020. Perhaps open a new case online and request a downgrade to 25.14 to test stability. You could have Support downgrade just a single AP (or however many you want) to the older release so you can contain the testing to an area before downgrading all AP's.
Ryan / Meraki Solutions Engineer If you found this post helpful, please give it
Kudos. If my answer solves your problem please click
Accept as Solution so others can benefit from it.
