MR32 no longer broadcasting SSID
itontherock
We are running 4 SSIDs. One of our SSIDs has stopped broadcasting this morning. The other three are fine. Has anyone ever experienced this?
AnthonySysAdm
Same problem, 2 SSID, one not broadcasting anymore.
Recreating the SSID won't work, as it turn out our 4 APs can't communicate with the Meraki cloud for configuration update, yet report all statistics and connections to the dashboard properly.
"Issue is with engineering", after 1h 1/2 hours spent with support...
5 Replies 5
RonSheeler
We are having the same issue. 3 SSIDs and 2 are not broadcasting.
AnthonySysAdm
RonSheeler
I did receive an update from support. Same as above.
Thanks for getting in contact with Cisco Meraki Support.
This is a known problem we have now and this has been forwarded to engineering. We will update you via the case, or feel free to ask for an update via phone.
Thank you,
itontherock
I just got off the phone with Meraki support and it is an ongoing issue with all Meraki APs and engineering are working on it now. Can't recreate it or anything for a work around as they won't update from the portal. Nothing to do but wait for Cisco to fix.
Gfuchs
We had the same issue across multiple sites.
Came back up @ 8:48 AM EDT
