MR32: client not associated
Puyi
Why are there so many "client not associated" error? And this "event not logged" error?
my Meraki AP firmware version:MR 26.6.1
2 Replies 2
DensyoV
Is there any event in the air marshal page, i.e like packet floods or broadcast deauthentication? If none, I would recommend checking with Meraki Support if they can see anything from the backend logs.
Thanks,
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
Tadpole86
I can see that this is a single device having issues connecting. Have you tried updateding the client NIC driver?
