MR30.5 went from beta to stable release candidate.
The changelog were changed.
Old :
Wireless firmware versions MR 30.5 changelog
IMPORTANT NOTE
While Meraki APs have traditionally relied on UDP port 7351 for cloud communication, and TCP ports 80 and 443 for backup communications, with MR 28+ we are beginning the transition to using TCP port 443 as the primary means for cloud connectivity. In order to ensure proper connectivity to the Meraki cloud after this upgrade, please ensure that all “Meraki cloud communication” traffic specified in the "Help" > "Firewall Info" page is allowed through any firewalls or security devices that are deployed upstream of your Meraki APs. These requirements have been updated in November of 2022, so it is important that you review them. (Wi-Fi 6 and Wi-Fi 6E APs)
When configured for this version, MR12, MR16, MR18, MR24, MR26, MR32, MR34, MR62, MR66, and MR72 will run MR 26.8.3
BUG FIXES
General stability and performance improvements
WPA3 OWE AKM suite missing in beacons
Incomplete configurations when using VLAN profiles
Intermittent connectivity loss for Windows client devices
When using WPN, DHCP requests are missing option 55
KNOWN ISSUES
Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 5 Wave 2 and Wi-Fi 6 APs)
In high capacity wireless networks APs may experience instability when the “Client Balancing” or "Band Steering" feature are enabled
New :
Important note
Bug fixes
When using VLAN profiles, APs may have failed to associate clients (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
WPA3 OWE AKM suite information was not included in AP beacons (Wi-Fi 5 Wave 2 APs)
When using L2 isolation, Windows clients may have experienced connectivity issues (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
When using WPN, DHCP requests did not include option 55 (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
In high capacity wireless networks, APs may have experienced instability when the “Band Steering” feature was enabled (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
Known issues
In high capacity wireless networks, APs may experience instability when the “Client Balancing” feature is enabled (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
Yay 🎉🎉😎
