MR18 or MR30
RumorConsumer
MR18 or MR30
You get to be wirelessly connected to one of them. Whichever one you choose has a wired connection to the switch so gateway not repeater. Which do you choose?
The one with the higher data rate at a signal level that I can sustain.
RumorConsumer
touche. ill test them out.
SoCalRacer
Depends on a couple things, device connecting and what the use case, etc.
Personally with my current devices/setup MR30 all day.
kami
Hi Rumor,
I like to go with MR18. There are different features, but what I like at most are:-
Ingegrated enterprise security and guest access
Hig performance mesh
Automatic RF optimization with spectrum analysis
If you want to know more. You can go through this article. FYI:- https://meraki.cisco.com/lib/pdf/meraki_datasheet_MR18.pdf
Please also let me know. How did you find this information?
Thank you.
Regards,
Kam
