MR's with dual ethernet
FrankHWB
Do these dual ethernet AP's allow for ethernet OUT to addtional AP's or networking?
i guess my question is can they act like a 2 port switch?
7 Replies 7
VivekT
Yes, a Meraki AP port (particularly on models like MR52, MR53, MR53E, MR84, and MR57 with dual Ethernet ports) can function like a 2-port switch, allowing you to connect wired devices directly to the AP and pass their traffic through its Ethernet port, provided you configure a "Port Profile" on the AP to enable this functionality; however, you must disable link aggregation on these models if you want to use the second port for wired clients instead of uplink aggregation.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/Port_Profileshttps://documentatio...
FrankHWB
thank you,
and the same goes with the newer CW models?
also the link in your reply returns a page not found...
RWelch
AP Port Profiles
RWelch
MR Link Aggregation Configuration Guide
RWelch
MR57 Dual Uplink High Availability
Brash
The only Catalyst AP that includes dual RJ-45 interfaces is the CW9178.
And yes, it can use the second interface to extend the network.
https://documentation.meraki.com/MR/MR_Installation_Guides/CW9178I_Installation_Guide#Extending_the_...
VivekT
Please share the model of CW access point.
MR supports the feature you want.
