MR Teleworker VPN
ELyesD
MR Teleworker VPN
Can anyone please provide some information about how AP builds the VPN with Meraki MX? does it contact the MX public IP then fallback to its private IP? or it only contacts the public IP?
I explain, we have a MX used for L2L VPN and AP teleworker vpn. we use manual NAT and unfortunately this parameter is global. We cannot (do not know where to) put the MX private IP for the AP and the MX public IP for L2L VPN.
the MX is behind a checkpoint firewall and the checkpoint is dropping UDP traffic from AP (internal IP) to the MX public IP (issue with the checkpoint). So if the AP fallback to to the MX private IP, i will just block public traffic and allow private traffic.
What do you think about this?
timeshimanshu
@ELyesD  Follow https://meraki.cisco.com/lib/pdf/meraki_datasheet_vpn.pdf for detail understanding on MR Teleworker VPN.
BrechtSchamp
Both the teleworker VPN and the AutoVPN between MXs use the same hole-punching technique. Both endpoints of the tunnel register themselves in the cloud. When a tunnel needs to be established between them, the cloud will look at those registrations. If both are behind the same public IP, they'll try the local IP addresses first for the tunnel establishment.
More info here:
https://documentation.meraki.com/MX/Site-to-site_VPN/Automatic_NAT_Traversal_for_IPsec_Tunneling_bet...
And also in the excellent whitepaper linked from that page, it explains in detail how this process works and how the private IP addresses are tried first (chapter 3.3 "Peers behind a Common NAT"):
http://www.brynosaurus.com/pub/net/p2pnat.pdf
ELyesD
Hi BrechtSchamp,
Maybe I am confusing the words but I mean Access Points when I say Teleworker.
the APs and the MX are behind the same firewall (Checkpoint) and this Checkpoint doesn't like UDP from AP to MX public. it drops the traffic...
So I woundred if the APs fallback to MX private IP or not
Thank you for the docs, I will read them ASAP
BrechtSchamp
Yes, that's what I meant too :). The AP will try the MX's private IP for the VPN tunnel.
