MR-86 antenna
Michael_Borbon
MR-86 antenna
Does the MR86-HW will work with 2 antenna?
Thank you
Brash
As per the FAQ, all ports should have antenna connected.
"On a 4x4:4 AP however such as the MR84 and MR86, there should be no unused ports. These APs have four dual-band antenna ports (and therefore do not have 2.4 or 5GHz labels). None of these ports should be left unconnected because all four ports will always be active even if one radio is disabled. MR84/86 APs should have all four antenna ports connected"
https://documentation.meraki.com/MR/Other_Topics/Frequently_Asked_Questions_regarding_Cisco_Meraki_A...
Michael_Borbon
What happened if the user has 2 antennas only. Because he only purchase 1 quantity for Mr86. The AP will no longer be used? Or you could still used the AP with 2 antennas? Thank you
Brash
It will probably 'work' but you may have unexpected issues. As the link states, the radio's will be enabled regardless of whether the antenna are connected or not
