MR 33 AP's will not connect to raduis server (TACACS)
ccall678
VLANS allowed on Trunk are correct for Data VLAN. Both switch and router onsite have TACACS Functionality and Radius/TACACS server can be pinged from AP's on dashboard. But Packets do not return to AP's and test on SSID that will be utilizing Radius fails.IP addresses are entered into Radius as well. Radius configuration is correct including port and key. What am I missing?
Rudi
What type of authentication are you using?  Username/PW? Certificate based? Have you tried the test option from the SSID page on your dashboard, or just tried connecting a device to test?
In my scenario with 802.1X certificates the test from the Dashboard fails, but devices connect properly.
What does your RADIUS server log say?
We have set up RADIUS server authentication in this Access Point (AP). However, we are facing issues while trying to log in using RADIUS authentication from our laptop. Even though we have tested the RADIUS, and it passed the authentication, we are unable to connect through the AP using the same credentials.
CFStevens
Hi @ccall678 ,
Have you tried taking a packet capture off the RADIUS server's uplink interface, or the switchport directly connected to the RADIUS server to confirm it is getting RADIUS messages? If so, are you seeing the RADIUS server then send RADIUS replies back towards the AP?
