We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Is it possible to require MFA for WiFi access using the Meraki MR? Is there a setup guide? We would be using Azure/MS Authenticator. Thank you.
Solved! Go to solution.
Yes - but it is a terrible idea so no one does it.
Every single time some re-associates (such as roaming between APs, goes out and back into coverage) they would get another MFA prompt.
Thank you. So what would be best practice? Certificate based?
Yes - use certificates.
