MA-MNT-ANT-2
Gian
Just browsing
MA-MNT-ANT-2
Good Morning everyone,
I have to mount some MA-MNT-ANT-2 but on installation guide https://documentation.meraki.com/MR/MR_Installation_Guides/MA-MNT-ANT-2_Installation_Guide there is only the length (33cm). Someone has got more information or a more precise datasheet?
2 Replies 2
The MA-MNT-ANT-2 is an extra-long mounting arm designed for the MA-ANT-3-E and MA-ANT-3-F wide patch and narrow patch antennas. It is 33cm (13 inches) long. There is a separate, standard mounting arm option with the MA-MNT-ANT-1, which is the same product except the mounting arm length is the standard length (22cm or 8.7 inches).
The MA-MNT-ANT-2 is designed with an articulating, extended-length arm that allows for mounting the MA-ANT-3-E and MA-ANT-3-F patch antennas to wall and ceiling surfaces1. The mount comes with 5° mounting marks for precise coverage angles.
Gian
Just browsing
Nowadays works for MA-ANT-6-E and MA-ANT-6-F. My question was about specific dimension like arm width, thickness and distance between arm joints
