MA-ANT-3-E6 pigtail length
Fabios1
Does anyone know the length of the pigtail for the MA-ANT-3-E6 antenna?
I'm not able to find in the datasheet, and not able to find the antenna installation guide.
Regards,
Fabio
If I'm not mistaken it's 1 meter.
meraki_datasheet_MA-ANT-3-E.pdf
Frequently Asked Questions for Cisco Meraki Access Point Antennas - Cisco Meraki Documentation
2 Replies 2
Fabios1
Hi Alessandro, thanks for the answer!
Yes, I can see now. I think that is the 1M after the cable model (AA-9303, 1M). I looked quickly looking for 'cm' or lower case 'm' or length.
Regards,
