Sorry for a dumb question but I cannot find a clear answer to it. Could someone please explain what is a difference between MA-ANT-3-D6 and C6 Meraki antennas? AP - MR46E if that makes a difference.
Looking at radiation pattern they look rather similar just one is "downtilt", meaning what ? 🙂
Am I right to assume that C6 has a "doughnut" center at its own body, while D6 has it pushed down from itself (vertical view I believe)?
So in case of racks being 7-8 meters in height and antenna mounted at 10-11 meters D6 is much better option as will create less interference between AP?
Thank you!
