MA-ANT-25 connection to an AP MR-74
LMatos
I guys, hope you are fine.
I've a MA-ANT-25 to install in an AP MR-74.
The antenna is dual band, so I can connect one connector to a one radio (2.4Ghz) and the other connector to the other radio (5Ghz), or I've to connect the 2 connectores of the antenna to the same radio of the AP? If this is the case, If I want dual band, I've to install 2 antennas, correct?
Best Regards,
LMatos
LMatos
The answer is that I've to connect the connectors of the antenna to the same radio, so If I want dual band, I've to install 2 antennas.
Best Regards,
LMatos
1 Reply 1
LMatos
Best Regards,
LMatos
