- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Location Analytics - Data Suddenly stopped !
I have an MR32 AP and have Location Analytics enabled and scanning API posting to a System that detects presence of devices.
Two days ago the post URL stopped receiving device updates.
Looking in the Organisation Wide Location Analytics the data and graphs showing various devices seen dropped to Zero despite plenty of Wifi Connected devices.
I updated to latest firmware but its still the same.
No Config Changes made at the time it stopped.
Has anyone seen similar ? Not sure why data is suddenly lost !
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I had this happen a couple months ago. It was a problem affecting one of our shards. Meraki had to fix it on their end. Call support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you using https on the receiving server? Maybe an issue with the certificate?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi All, thanks for your responses - I contacted support and it seems the development team were working on the shard that I'm on and they had reports of others having lost some services that were on there, not long after I raised my case its started working again 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which system do you use to detect presence of devices?
I really want to try the Scanning API feature but I don't know to which kind of system i should post.
Any information is very welcome
kind regards
Alex
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello
You could use something like Home Assistant if you just want to test it, that's an open source home automation platform.
Grant
