Local Auth on MR using LDAP - Certificate Trust Problem
ajtsystems
I've set up an SSID to use Local Auth for RADIUS with an LDAP server for authorization.  I'm using 802.1x with the suplicant passing machine certificates issued by our own CA.  Everything is working and clients are connecting, however in Windows 10 before they connect Windows is prompting asking "If you expect an SSID in his location, continue"
In the SSID, there are RADIUS Trust client settings that show a Root CA certificate that has been used to sign the meraki.radius.direct certs presented by the APs.  I'm pushing the client settings via Group Policy, but for some reason I can't get the client to trust the Root CA which is "IdenTrust Root CA 1"
Has anyone else had this problem?
The root CA IdenTrust Root CA 1 is in the Trusted Root CA store on the client but for some reason I am still getting prompted for user interaction
2 Replies 2
Have you tried performing a packet capture?
ajtsystems
No but that's a good idea
