LDAPs
EDogcooter
LDAPs
Has anyone had any luck with using the my LDAP server Splash page to authenticate users when connecting to WiFi?  We use Azure AD with AADDS with LDAP and can't get it to connect.  The NSG is configured to be open at the moment.  Any ideas?  I really don't want to incorporate a Radius server if I don't have to.
1 Reply 1
Rebry
I do believe the LDAP needs to directly connected with VPN for this to work. Do you have a direct site-to-site connection between your site and azure?
