Issue when creating IPSK via API
PCEthanK
Just browsing
Hi All,
I have been testing creating IPSK's via the API and am running into an error.
When I make the request, I can see the IPSK appear, but then am not ale to use it to connect to the wireless, if I then go into this IPSK record, click done, then try to save changes, I get this error
And this is the record that was created
And this is the body of the request (noting that their documentation specifies that if the expiry is not specified then it just won't expire)
Hoping someone can help me!
2 Replies 2
RoshanS
Greetings,
If you are still running into the issue, I would suggest contacting support and/or opening a case so that we can attempt a recreate and investigate further.
GIdenJoe
Strange, it looks like website is not pushing the fields to the body of the API call.|
Did you initially add an iPSK on the GUI or did you immediately start with doing API calls?
It is possible that when creating the SSID the first time you need to already have 1 PSK and GPO in place to add this.  And perhaps you can then via API add multiple key/GPO pairs.
