Inter VLAN communication
IanTerry
Hi
I have an MX65 configured with 4 VLANs (1681,1682,1683,1684) - basic setup 192.168.1.x/24, 192.168.2.x/24, 192.168.3.x/24 and 192.168.4.x/24 - the MX IP uses .254 for each subnet. Each subnet configured to provide DHCP using a pool .100-254
Trunk connection to a switch from MX. Switch is 24-port with 6 ports allocated to each VLAN for wired connections
MR55 is configured with 4 SSIDs - each SSID is associated to the VLAN - e.g. SSID-1 = 1681 (192.168.1.x) SSID-2 = 1682 (192.168.2.x) SSID-3 = 1683 (192.168.3.x) and SSID-4 = 1684 (192.168.4.x)
Wireless clients get IP addresses within each SSID
Why can't a client in SSID-1 connect to a service in VLAN 1684 ?
This should be just simple internal routing between local VLANs/subnets
Is there something missing?
Any help gratefully received.
MR55 is configured for trunking of the
Have you by chance got the MR firewall configured to deny local LAN access?
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/'Deny_Local_LAN'_settings_in_Cisco_...
IanTerry
Yes that was it - many thanks and apologies for the newbie question.
PS. still can't work out the MX trunking issue, have a switch between the MR55 works, going direct to the MX it doesn't. Will raise to Meraki to see what the issue could be
kYutobi
Try a different trunk port and make sure the native VLAN is set. Just for giggles.
Enthusiast
IanTerry
Thanks for the suggestion but tried that previously, same result.
Factory reset worked. BUT. now a second MX recently purchased is doing the same darn thing! Something isn't right so pushing this back to the distributor
