ISE & Meraki Guest Integration WPA2-PSK
JamesB
Just browsing
Is there any way of integrating a Cisco ISE Guest Portal with Meraki wireless in a manner which will secure the traffic (e.g. WPA2-PSK)? If this isn't possible at present, is it on a roadmap?
6 Replies 6
Roska
I´ve seen a Cisco communities thread and a doc file on ISE & Meraki integration. I will share it via PM.
Oskar
MRCUR
This is the ISE-Meraki integration guide: https://communities.cisco.com/docs/DOC-68192
MRCUR | CMNO #12
JamesB
Just browsing
Unfortunately that only caters for Open or MAC-based, not WPA2-PSK (for the Guest network).
MRCUR
Have you considered switching to the Meraki hosted guest auth/splash setup? We use this quite successfully across a number of networks and deploy the guest SSID with a PSK and then present a sign in page.
MRCUR | CMNO #12
jdsilva
You can only do MAC based or WPA2-Enterprise. WPA2-PSK isn't supported (by anyone AFAIK when you're doing RADIUS).
JamesB
Just browsing
I think you can do this with a Cisco WLC... can't say for certain though...
