I have one query regarding SSID configuration using template.
Bdas
Can I create a SSID for multiple networks using template?
If so, what are the things I need to be careful about? Like if I map the networks to the new template, will the networks lose any existing configuration?
Yes, you can.
https://documentation.meraki.com/Platform_Management/Dashboard_Administration/Design_and_Configure/O...
Note: When binding an existing network to a template, its current configuration will be lost and it will begin using the template configuration.
Bdas
So that means entire existing configuration will get removed.
yep
pdeleuw
Yes, existing config will be removed. If you unbind the network from the template, you have the choice: Restore the (pre-template) configuration or keep the template config.
