How to remove myself as member of someone else's Organization?
aluminumfoil
Hi all. I'm done with a project assisting with an outside Meraki setup and I'd like to remove their Organization from my Meraki portal (and revoke my access). I'm seeing options to remove/edit other members but no icons next to my name to make changes. Thanks.
It sounds like you don't have rights to edit Administrators.  You will need to ask one of their Administrators to remove you.
If you go:
Organisations/Administrators
You should be able to tick yourself, then then click delete at the top.
Ah. I just noticed I don't have Organization listed when I go into theirs (just Network-Wide and Wireless). Any thoughts?
Shoot. Thanks for the confirmation Philip.
