How to disconnect clients from the wireless network
ctalavat1
Just browsing
I am trying to disconnect clients off of specific SSIDs on the wireless network.  I'm not sure what the correct process is.  I have tried to change the policy to "block" but it didn't seem to work.
5 Replies 5
What type of authentication are you using? Note that the block option will not disconnect the user, it will only prevent them from accessing any resources.
If it is a network with PSK, you can only change the password.
ctalavat1
Just browsing
I have smart phones, on a SSID, that I need to kick off the wireless.  I don't see any options to do that with my credentials.
ctalavat1
Just browsing
My boss got a hold of me and gave sent me some guidance.  Thank you for your help on this matter.
nilspecial
Could you please share your solution? I have the same problem.
