For domestic use, there are problems with using Meraki with respect to the lack of a functioning IGMP-Proxy on the MX range of kit. This need not mean Meraki kit cannot be used, one may place a third party security gateway upstream of the MX and siphon off all the goats (guests, smart devices, multicast IP TV, Audio Visual kit, security equipment, lighting systems etc) to the "Wild West" leaving the sheep to pass through to the secure Meraki network (the promised land).
Unless you are using 802.11ad technology, mesh systems are going to compromised in terms of throughput (802.11ad is generally not supported by manufacturers, yet). If users are streaming videos, then throughput quickly becomes an issue. My rules of thumb is to wire any device that does not move, and avoid wireless uplinking), place a small WiFi AP in each area that requires WiFi, as one has no idea what is in the walls, or how thick they are; some wall board even has foil coating which blocks signals.
There are lots of buildings which people imagine cannot be wired, until they buy a high end audio system or home theatre, at which point they discover that making holes in walls is easier than they imagined. There are some very good installers around, they tend to be expensive.
