We have the following WiFi setup at one of our offices. 10 Cisco AP’s being managed by a Cisco Wireless Controller there are two main SSID’s for the office a Corporate and Guest. The corporate WiFi is routed over the WAN and the Guest is routed out via a dedicated DSL line.
The DSL router is plug into a network and a VLAN has been assigned to the port and the Guest interface on the Cisco controller has the same VLAN assigned.
Devices on the corporate WiFi receive a DHCP address from the local DC and devices on the Guest receive an address from the Cisco Controller.
So it’s been decided that we are going to replace the existing Cisco AP’s and Controller with Meraki AP’s and cloud controller which is simple enough but they still wish to use the DSL line for the Guest SSID which seem to be a little difficult.
If I set the SSID to NAT mode I can get a DHCP address from the Cloud Controller but this does not sort VLAN’s and will not use the DSL line. If I put the SSID in Bridge or Layer 3 mode I can VLAN it off to the DSL Line but there is no DHCP server, so the devices do not get any addresses.
Has anyone come across this situation or have any ideas. The only ideas I can think of is either put a small MX appliance in or use the current router.
Dave
