Guest WIFI has network access then it doesn't
Jayt
Odd thing happened on Thursday. All of a sudden the guest WiFi clients could access my local network.  Confirmed by 2 different devices from different locations.  Then today when I go to test it's again being blocked.
I disabled the guest WiFi once discovered & re-enabled it today.  I did update the MR firmware for all AP's to 30.05 today as well.
Ideas??
I suggest you open a support case.
If you look at the dashboard audit log, were any other changes made?
UKDanJones
Sounds like a config issue… disabling and enabling probably resolved the config slip.
Please feel free to hit that kudos button
