Hey guys. I've had a few users complain of not being able to see the CAPTCHA when trying to reset their password via the link on the splash page (https://account.meraki.com/account/reset_account_password). The last time I opened a case, I was told it was Google's fault since they have that service. A case before that though, Meraki said it was something on their side. Has anyone else gotten the reCAPTCHA errors lately? The weird thing is that when I visit the link while connected to a Meraki AP, I get the 'I am not a robot' CAPTCHA but it just spins when the box is ticked. On any cellular and any non-Meraki network, I don't even see the reCAPTCHA at all.
I assume the only workaround for now is resetting passwords thru the Dashboard.
@EClap5 Have you set your config to block all traffic until authenticated? If so it may be blocking the traffic to Google which is why its going nowhere.
It looks like Meraki has update the forgot password link from account.meraki.com to account.network-auth.com and now the reCAPTCHA works again. There was a major reCAPTCHA outage over the last few days but everything seems to be working again.
Adam R MS | CISSP, CISM, VCP, MCITP, CCNP, ITILv3, CMNO If this was helpful click the Kudo button below If my reply solved your issue, please mark it as a solution.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_d9b0d5164d35a","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_d9b0d5164d35a_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_d9b0d5164d35a_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_d9b0d5164d35a_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_d9b0d4acf4bad","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
