Going to add another MR33 access point.
mholzer54
  Anything I need to consider.  I want them on the same SSID.  Or do I just plug it in to my POE switch and configure it like the other one?
BHC_RESORTS
Once you order it, you should get a dashboard key (or order number). Add the license to your dashboard, and the device will populate to your inventory. Add it to the appropriate network (if you have more than one), and then it will automatically obtain its settings once plugged in to the switch - so long as you have the SSID set to broadcast to all APs.
BHC Resorts IT Department
1 Reply 1
BHC_RESORTS
